No power to head lights checked fuse battery is hooked up. Checked switch replaced it no head lights.Tail lights work runing lights work.. Both l/h and r/h relays have power at post 3 and 5..Dont seem to have power at h/l dimer Do you Where the ground for my head lights is at? . Now i I did check the headlight plug last week had power at both thought sweet..well later that day hooked up the plug at the light and battery(i had to charge my batt) tryed my lights no dice.So I checked the plug and had no power..So a.ground intermitente issue would make sene... Is thier a point where all of this intersects? Or are they grounded in the same spot?
